Im not to farmilar with the ol rampages but it sounds like your asking for a sending unit and your being shown a switch(sending unit three prong or so and swith only one) hope i didnt misunderstand! Your fuel gauge issue can be checked pretty simple, disconect the level unit at the tank and with a jumper wire, ground the level unit signal wire on the harness side. Make sure the key is on, engine off. have a helper watch the gauge, if it goes to full when you ground the wire, the wireing and gauge are good and the level unit is defective. You will most likely have to drop the tank to get to it. Hope this helps. Good luck!!
