help needed to identify charger 1972
Old 07-21-2010, 01:50 PM
Junior Member
Hjukke's Avatar
Hi, i imported 1972 charger from mexico to finland last month. The thing is that vin of the car is different: it is very short and the plate is on driver side door sill: T2-H15477. Car also has kmh speedo, it must me some kind of export model? Engine is 340. Im trying to figure out what were the factory specs of the car. That same number is also on the old original registration document.
Old 07-21-2010, 03:28 PM
mopardrt's Avatar
there is no vin on the dash?
Old 07-21-2010, 06:27 PM
blue 68 gts's Avatar
Should still have a VIN on the dash, but it would have an export number I THINK on the support core. Don't quote me..
Old 07-21-2010, 07:19 PM
A.K.A Bob Dodge
1966sportfury's Avatar
just quoting you, cuz u said not to.
Old 07-21-2010, 09:45 PM
Junior Member
Hjukke's Avatar
It doesnt even seem to have the marks from the rivets on the dash where the vin plate should have been.. Have to keep looking.
Old 07-22-2010, 02:49 AM
Polaradude's Avatar
Cool vin, I have never seen one like that before.
It's a strange configuration for that group of years.
Logic would dictate that the vin would have a "P" in it for export. Also during that group of years the "H" can mean two things depending on location on the tag. The H denotes a Charger Coupe in 71-74 and also the 340 4 bbl 240 hp.
Please keep us posted to anything you find out.
Also can you find block and head numbers ?
Perhaps the block # is 2780930 and heads may be 3418915
Old 07-22-2010, 04:28 AM
Junior Member
Hjukke's Avatar
Thanks already for everyone trying to help me. I found another number in original bill of sales, 2313785 but i dont know if that helps any further anyway. Intake casting number is 3512100 which refers to 1971 340ci. I´ll be working on other clues...
Old 07-22-2010, 05:05 AM
Junior Member
Hjukke's Avatar
I found number c-30652 chgd on drivers side exhaust manifold.
there is also 7-digit number on passengers side fender (quite close to hood).
It is not very clear any more how to read it, it might be C202430 (4 may be A as well) or 820a131 (or 620a131). Could it make any sense if the zero was 3 (then 23 would mean the 2dr coupe). Quite an investigation..
Old 07-24-2010, 03:25 AM
Junior Member
Hjukke's Avatar
Photos:
http://koti.mbnet.fi/hjukke/charger3.jpg
http://koti.mbnet.fi/hjukke/charger4.jpg
http://koti.mbnet.fi/hjukke/charger1.jpg
http://koti.mbnet.fi/hjukke/charger2.jpg
http://koti.mbnet.fi/hjukke/charger5.jpg
http://koti.mbnet.fi/hjukke/charger8.jpg
Old 07-24-2010, 05:33 AM
mr340's Avatar
Body style proves it is a '72 SE probably not an original 340, the hood is not original, and the taillights are also not original to the SE. The SE was more luxury than preformance, they were available in 318 400 and 440, not 340.
Old 09-27-2012, 04:03 PM
mista's Avatar
Up. Any info on this case..
Old 09-28-2012, 01:45 AM
mista's Avatar
I'm interested on this case because i have also Charger 1972 wich is imported from Mexico in 2010. Vin has only few digits different than this one and none of thosed basic fender tags etc..
Is there any place to decode mexican vins or even someone who could tell me something about mexican chargers in general..
Old 09-28-2012, 11:44 AM
Maybe a theft recovery that was re stamped by motor vehicle dept
Old 09-29-2012, 10:08 AM
Chryco Psycho's Avatar
The Mexican built car were very different , the Vin sounds correct to me T2-H15477., you may find a plate welded to the frame rail also with the same # . my friend has a 70 Super Bee [ Duster] all documented with a similar VIN & a plate on the left frame rail
Old 09-30-2012, 10:35 AM
mista's Avatar
left frame rail.. Can you be more presice.. This is my first car like this
Old 06-26-2013, 09:34 AM
mista's Avatar
Lets wake this thread up.. Maybe someone new has seen win like this somewhere?
And if someone has same car with hide away headlights please send picture here from the center parts behind the grill.. I think the headlight opening motor is located? Mine is not original and i haven't seen one. I'd like to redo it to make look like original..
morepar
09-14-2012 10:40 AM
morepar
09-09-2012 06:54 PM
indianfield
12-02-2011 06:49 PM
lynchroad
01-20-2011 01:41 AM
bigdaddy
07-02-2008 05:29 PM
Quick Reply: help needed to identify charger 1972
