360
Old Nov 5, 2007 | 07:03 PM
ccflash22's Avatar
Member
Be very glad you found this forum. This information is PRICELESS. Alot of trial and error has went into this info.
Kenny
Old Nov 11, 2007 | 02:04 PM
Sixtysix, you are obviously ahead of me, specially on the later generation engines, but there might be one other thing:
For those wanting to go with a manual box, at least in the engines I'm familiar with, Chrysler was FAMOUS for NOT doing two things to an "automatic" crankshaft--
The crank may not be drilled deep enough to accept a stick, so you either have to bore the crank, or cut off a little of the pilot shaft
and...
many weren't bored to "standard" pilot bearing size, either. You USED to be able to buy undersized pilots for auto cranks, from good parts stores.
(First time I saw a 4 speed with about 1/2 missing from the pilot, I'm like, WTF??)
Old Mar 12, 2010 | 07:54 AM
TNRocker86's Avatar
Junior Member
318 to 360 swap
I just recently purchased an 1983 Dodge Ram D150 with the LA 318. That didn't put a LA 360 in that truck until 84 if I'm correct.
I happened to luck up and came across a Jasper 5.9 360 in a 1996 Dodge Ram 1500 at the salvage yard that had been hit in the passenger side and totaled the truck. The motor looked brand new, as did the block, valves, everything all around. Anyways what I have done so far is I swapped out the intake manifold and put a Edelbrock Performer intake on to convert over to carb instead of fuel injection. That eliminated the wires and computer and anything I should have an issue with. What I DID have to do was replace the magnum 360 water pump and timing chain cover with the LA style 318. Which the LA 360 SHOULD work too but went with the 318 as it bolted right up and still had that one to save some money. As far as the torque converter issues. As some have stated. That's correct the Magnum 360 or I think even the LA 360 was externally balanced. Now just because I don't have money to just blow. I'm using the same transmission that was in the truck as well as torque converter. Reason I'm doing this is 1)I can't afford another torque converter at the moment. and 2) From what I'm understanding. The torque converter was balanced however since the truck I got the motor out didn't have a torque converter or tranny in it, I was looking at the motor and found that the flywheel (Not sure what chrystler calls it but it's the aluminum peice circular peice that the torque converter attaches too. Anyways that peice on the motor was balanced. It has a weight on the top and one on the bottom of it. Now my conclusion led me to this. If that's already externally balanced I might NOT need to have a balanced torque converter. But then if theres vibration when I get it running, then I prob would just need to try knocking the weights off the flywheel? (I'm just looking for a quick temp. fix until I can afford the torque converter, IF I end up needing it).
As far as everything else I've seen so far, everything else pretty much bolts right up. As far as motor mounts. You would have to change them out atleast I know I have to. Right now though I'm port/polishing the heads, and replacing the timing chain, and gears with a Comp Cams Performance Series Double Magnum Roller Timing kit. Just something to keep people informed about. When I chose to do this project instead of just installing a LA 360 I chose the Magnum 360. Understanding that the parts would be more expensive then that of the LA 360. For example: Summit Racing has a Comp Cam for my motor but asking $305 for it. All because the magnum 360 uses roller lifters and a few minor things. As the LA 360, you might be able to get a good Cam for around $119 or a little more. So if you're wanting to swap out that old LA 318 with a 360. Research the prices on different parts and everything, and make sure you understand if you go with the 360 Magnum instead of the LA, it WILL be more expensive. Also minor things I've come across. MY 360 motor by Jasper the intake manifold bolts straight down instead of at an angle. So either a dual bolt pattern or straight down bolt pattern was required for mine. As well as my Valve covers are 10 bolts instead of 5.
Old Apr 5, 2010 | 09:43 AM
TNRocker86's Avatar
Junior Member
LA 318 to Magnum 360
Hey I have an 1983 Dodge D150. I swapped out the LA 318 and put in the Magnum 360. Converted it over to carb and everything. Now, finally got the truck running and have took it around the block twice. However, the problem is this. How do I get the alternator and compressor to line up where it's supossed to be so all the belts will go back on it? I changed over the pulleys so I could run the old school v-belts. However the compressor and alternator pulleys were already v-belt from when the old 318 was in it. Not sure if I'm missing something or will I have to fabricate some type of plate to hold the compressor and alternator out forward a little bit more? Thanks in advance for the help!!!
- Jon -
Old Mar 5, 2018 | 03:22 PM
Jay Corbin's Avatar
engine rebuild
does and anybody know how far a 1996 5.9L 360 can be bored out to? I'm planning on turnin that 360 into a 440 small block and puttin it in my 1996 ram 2500 and I can't get any answers from mopar on it.
Laura Cullen Reynolds
Apr 22, 2024 03:24 AM
jej
Nov 17, 2014 07:59 AM
keith811
Jan 13, 2011 10:43 AM
choelzer
Feb 29, 2008 03:00 AM
