383,440 and 400 compatability
Old Nov 10, 2007 | 05:58 PM
Big block heads should pretty much interchange, but there ARE some differences. Earlier heads, like the single 4BBL 426 and the "pre Roadrunner" 383 heads didn't have decent ports.
383's don't really have 440 heads, it's just that "they are the same." Speaking here of the 335hp 68 and later heads.
If you can find the rare 66-67 440 GTX heads, and I've forgotten the casting no. (907? 903?) you've got a rare pair.
HOWEVER--some of the later heads might be even better FOR YOUR application. This is because later "smog" heads, even though might have larger combustion chambers, and might be lower compression, have better valves and seats--for no lead fuel. This can be an advantage on a street car on pump gas.
The things that will NOT fit between 413/426/440s and the 383/ 400's is the intake, distributor, (I think) rods, pushrods, and without major mods, the crank.
Old Nov 15, 2007 | 10:57 AM
Damn, I wish you'd learn to type with good grammar. Your posts are hard to read.
Worrying about swapping 72 for 73 isn't going to gain anything
There was no such thing as a '70 with "smog heads"
Old Dec 30, 2007 | 06:56 PM
deadkelly's Avatar
about compression
Originally Posted by 4004speedrunner
ok so I mis enterpreted (sp?) what was written sorry for the confusion (and sorry for bein rude 66) so I should try and trade off my 72s for 73 to ? (need to find production years) 400 heads and rebuild them using Kbs and if I had the heads that came origanally with it I would use them but I don't also I ran across something the other day and it interested me the stock compression for a 70 440 was 9:7.1 with a pair of smog heads that run on unleaded that make the same comp. Could I run that compression ratio on the street or is the cut off 9:5.1 if so I may just fubar the 400 and go with a 440 hell I don't know I need to decide quick though the last thing I need is my mom getting po'ed because im not getting it running once again thanx for all the help
www.doringindustries.com ,they make fuel catalysts. they do cost a bit, but ol mate who all our head work says everything with a motor in australia should use them. iam getting one and it will cost bloody heaps but so do engines. i hope its worth it...
Old Dec 8, 2012 | 08:48 PM
Spc Steve Graves's Avatar
the only diff between the b and rb is the deck height the rb is 3/4 of a inch taller your distributor and push rods are diff and your int a mag head has a smaller chamber compression witch bumps your compression up now if its just stock 440 heads no add on but 383 or 440 mag heads good choice
Old Dec 8, 2012 | 09:37 PM
At this point use what ever heads you have.. Put your money into the short block.. IF you have a 440 motor use it !!! Have a 400 use it both can be built to produce good HP
Old Dec 9, 2012 | 07:42 AM
Gorts 5th's Avatar
Smile
Originally Posted by SixtySixDeuce
The short answer is no. 361, 383 and 400 are B blocks, 426 MW and 440 are RB blocks. 383 and 400 heads interchange, but it would be akin to puttin 318 heads on a 360 or vise-versa. The smaller chambers of 318 heads (higher compression) is negated by the smaller ports. In the case of 360, the reverse is true; the ports flow much better, but the combustion chambers are much larger than 318 and will drop compression on the 318. It ends up being a wash, performance-wise.
If it is a 400 you're building (correct?), and trying to do so on a budget, your best bet is to hone it and drop in some speed pro or KB hypers and just port the heads you have. Swapping cranks, decking blocks, milling manifolds and heads and all the other things that go into strokers and the like gets expensive quick. Shoot, just building Mopars gets expensive quick. The cost of building moderate street engines seems to run right about $10 or $12 per horsepower. Sometimes I wish I was a Chevy guy.
don't nock that 360 318 head swap as a wash. i have personal experience with them and they make a big difference in performance gains.
and as far as a chevy guy goes the parts are so plentiful and cheap because the chevy small blocks where so cheap that they needed stronger parts to compete at any serious level
mopar has very durable parts you can say the mopar parts and engineering is second to none in the big three!
all this stroking and aftermarket pistons is stupid.
for the street a 383 can turn 7000 grand all day long on factory parts, the classic hemi rods are tough as *****! and unless you can find a better deal on pistons to raise your compression stay with mopar. flat tops are fine
years from now when speed runner is older and has more experiences driving and more flow he can go bonzi
Old Dec 9, 2012 | 10:04 AM
Chryco Psycho's Avatar
The 67 Closed chamber HP 440 heads are #915 btw
Old Dec 9, 2012 | 10:12 AM
Mr.4spd's Avatar
This thread is wicked old.
Old Dec 9, 2012 | 11:43 AM
Gorts 5th's Avatar
Smile
yea but it sparked this new thread.
don't nock 360-318 head swaps and chevy engines are cheap.
66 valiant Paul
Nov 16, 2012 05:17 AM
stickshifted
Jan 16, 2012 09:37 AM
joel
Feb 22, 2009 06:58 PM
CLJohnny
Dec 12, 2008 11:45 AM
Dartin'
Jan 3, 2008 05:28 AM
