Steering box, rebuild or replace???
Old 07-19-2009, 02:22 PM
64fury's Avatar
While searching for the cause of shaky ride, I found that my steering box has alot of play in it, I've played with the adjustments on it and can tighten it up a bit.
With the car parked on a flat surface, you can grab the steering column in the engine bay and turn it 1/3 of a turn either way by hand and pull and push it into ad out of the steering box about 3/4"
Is there a rebuild kit out there of these box's? How about a bolt on replacement box, I did a quick web search but could only find a flaming river replacement box at $800, which is a bit more than I can afford!
Old 07-19-2009, 03:14 PM
64fury's Avatar
Originally Posted by richinny
is that a manual or power box?
Sorry my Bad! It's a manual box for a 64' Sport Fury
I can find tons of Power Steering box's, but no manual box's so far!
Old 07-19-2009, 03:38 PM
Crazy4Carz.Com's Avatar
Forget it. The adjustments are there but a bad idea. The play exists because of wear. Do yourself a HUGE favor and get a quick ratio box. Check out places like firm feel. There are others as well. you can get a steering box that changes the ratio of turs of the steering wheel to the actual movement of the tires. Are you tired of having to turn the steering wheel twenty times from lock to lock (slight exaggeration) You can make it drive and steer like a late model vehicle.
You'll thank me later.
Old 07-19-2009, 03:59 PM
64fury's Avatar
Would love a firm Feel or Flaming river box, but the $800 CDN it would run me is way out of my price range right now!
Old 07-19-2009, 05:02 PM
challenger's Avatar
you can get a reman from carquest for about 450.00 but as C4C says you will thank him later so i would try and save the money for a closer ratio one verses a stock one and im sure if you do your home work you will be able to find one about the same price as a reman: but i dont no of any rebuild kit for wear but only seals but i could be wrong but i no the seal kit runs around 40 bucks
Old 07-19-2009, 05:36 PM
64fury's Avatar
Firm Feel list a rebuild kit with the 24:1 ratio (stock) for $175, just sent of a email to see if it would work with a 64" box.
Firm feel don't offer the fast ratio box's for the b-body.
Are tere any other interchangable box's that would possibly fit?
Old 07-19-2009, 08:59 PM
fury_19's Avatar
since we are on this topic of steering boxs... how easy is it to replace a power steering box? just curious but mine perfectly fine
fury_19's Avatar
and i dont meen the labor i meen to find the part
Old 07-21-2009, 08:19 AM
64fury's Avatar
You can find power box's almost anywhere, NAPA carry one, autoZone etc! And a rebuilt one costs about $225 plus core charge!
Old 07-23-2009, 10:06 AM
Mopar_71's Avatar
Here's a site that hs the worm and gear.. and a lot of other goodies. http://www.jimsautoparts.com/steering_parts.htm
I've bought some weather stripping from them and it was correct and fit good.
Last edited by Mopar_71; 07-23-2009 at 10:07 AM. Reason: The web address was wrong
Old 07-23-2009, 11:42 AM
fury_19's Avatar
thats good makes me feel more comfortable that they are easy to find
Old 07-24-2009, 09:43 PM
67Polara's Avatar
just get a different one i was having probs with mine took it out like 4 time n tried to fix it bfore i said screw it n went to napa n baught 1
Old 07-25-2009, 07:59 AM
64fury's Avatar
Originally Posted by 67Polara
just get a different one i was having probs with mine took it out like 4 n tried to fix it bfore i said screw it n went to napa n baught 1
I've tried NAPA, they only carry the power steering box, but we did only check under 64' b-body!
Are there later model cars that have a compatable steering box? ie: will a manual box from a 70's or early 80's b-body fit?
Old 07-25-2009, 08:34 AM
67Polara's Avatar
it might its worth i try, i tried pulling one out of a 1970 cuda but the... crab forgot what its called the rod in the middle of the box was to small, but look for one one the same size car and you might have some luck, i shelled out like 280 for my box.... but if you want theres an auto place a mile or so away from n they have some rarecar parts, i picked up a few parts for an 89 supra that had an engine imported from japan, n they seem to have all the parts for it so if you want i can call them and see if they have anything or can find onefor ya
Old 11-07-2010, 12:56 PM
1973runner's Avatar
napa box
just bought one for my 73 b body 135.00....an i still have 5 inches of play before the pitman arm moves, just like the old one...
Old 11-07-2010, 05:40 PM
This thread is so old............
How old is it?
It is so old it could get antique tags!
ottosen@chorus.net (08-05-2014)
Old 07-16-2012, 08:02 PM
sixxpac's Avatar
I NEED SOME INFO ON THE 1970 CHALLENGER TA STEERING BOX ALSO,I HAVE A TA AND THE STEERING BOX IS NOT THE TA QUICK RATIO ONE FOLKS ARE DESCRIBING,I HAVE PRT#2267262 IN MY CAR.WERE THESE TA BOXES STANDARD? IS MINE MISSING? PLEASE HELP WHILE I HAVE THE ENGINE OUT RIGHT NOW....SIXXPAC
Old 07-16-2012, 08:59 PM
The newer box Not sure when it changed ? The splines for the idler arm changed- larger. New box / newer idler They are pretty universal. I swapped the PS box from my 77 RR into a 67 Coronet... Same box as used in my Van.
Not sure who made it ?? There is a re enforcement bracket that can be added to the frame.
Also check the rag joint on the steering column..
Old 07-18-2012, 11:31 AM
Gorts 5th's Avatar
wat ever you do do it quickly my brothers worn box broke that WAS A SWEET SASY GRASS GREEN ROAD RUNNER
at least hes still alive .
Old 07-18-2012, 01:18 PM
Gorts 5th's Avatar
summit racing has a mopar kit
Mopar Performance Manual Steering Gear Worm and Ball Nut Packages
Replace your 26:1 manual steering production gear ratio set with these improved ...
325.99
Old 04-07-2014, 07:57 AM
  #24
smarchi's Avatar
Power Steering box
Hi, folks! I'm kind of new in this forum (it´s my first post). I recently had my '71 Cuda restored. I replaced my Gemer steering box for a rebuilt one, but even that is not smooth as I expected it to be. There´s no play, but it seems that it will lock in one position (I am exagerating a little here).
Has anyone experienced the same problem? Is there any adjustement I could make?
Thanks for your help.
I live in Sao Paulo, Brazil, and find replacement parts down here is quite difficult...
Old 04-07-2014, 12:02 PM
  #25
The adjustment nut is probably too tight or just a bad rebuild. The TA had special idler arms
smarchi (05-26-2014)
Snoblor
04-21-2013 03:11 PM
gh32
02-07-2010 08:16 PM
heminate
08-17-2009 08:07 PM
1 Bad Mirada
05-16-2009 05:24 AM
barron
01-31-2008 09:25 AM
Quick Reply: Steering box, rebuild or replace???
