Thread: Is it worth it?
View Single Post
Old 11-09-2007, 09:08 PM   #3 (permalink)
440roadrunner
Senior Member
Yep, it depends on whether you want to keep it original. If you put a 360 in there, those engines are externally balanced, and I'll guarantee you that you can "feel" that. I don't remember if the weights are on the torque converter or the flex plate
If the 360 is out of a pickup or other rear sump pan, you'll have to find a pan. Your 318 pan won't fit, because the rear main seal on the 360 is larger.
440roadrunner is offline   Reply With Quote
