View Single Post
Old 11-13-2007, 04:25 PM   #6 (permalink)
73DartSport
Junior Member
Just my opinion, but if you are going to do a rebuild...I would actually recommend an engine that has had more stress put on it...such as a motor home or truck engine. The reason I say this is that the block, heads, and internals have already gotten used to being heated up and cooled down and have done whatever warping they are going to do. You will find out that these engines while not being any stronger than others built the same way you are going to build yours seem to last longer after the rebuild. Good luck building your 440.
73DartSport is offline   Reply With Quote
