How to gear a Cuda for the street?
Old Nov 21, 2007 | 11:23 AM
That's a hard question to answer, it depends on you driving, what you expect out of the car, ???fuel mileage???
My old '70RR had 3.54's which with the G70 15 tires I used to run on the street gave me 3000 rpm at 70mph. It was just right, back in those days, but "we" spent several years with the dreaded 55mph speed limit, and the car didn't perform well with that gearing, and by that time I'd stepped up to taller tires, which made things worse.
Let me guess--you don't expect much mileage, you are building this for fun. Depending on your tires I wouldn't go any higher than 355 and if I could afford this, I'd probably use the biggest tires I could get under there, and 373 rear
Unless you tub the rear wells and can get REALLY tall tires under there, 411 and lower will be pretty low for any kind of freeway driving.
The other thing you might do, which I have not kept up on, is aftermarket transmissions--5 speeds and so on.
NYCuda
17
May 15, 2015 12:48 PM
fantastixvoyage
Jan 1, 2009 06:08 PM
Doc
Sep 17, 2008 05:10 PM
familyevents
Aug 20, 2008 01:24 PM
cxcxcxvcvcvc
Nov 20, 2007 08:10 AM
