318 wide block
Old Nov 26, 2007 | 02:57 PM
I agree, either rebuild the 318 or find a 360 crate motor. I assume you don't have unlimited funds. Converting to a big block can be expensive, and of course when you're done with the engine GENERALLY the Mopars of that body with 318's had worse (lighter) suspension and brakes, and no sway bars compared to the higher powered brothers. So that means that you can start in on THAT end of the car, too.
The 360's were externally balanced. I THINK you'd have to have the torque converter matched to the engine to achieve balance. In any case investigate that issue if you go with a 360.
Those old 318's have a lot of potential, are unique because of their looks, and there IS SOME interest in building them.
Google "poly 318", polysperical, 318, etc like that
http://www.1962to1965mopar.ornocar.com/poly318.html
http://victorylibrary.com/mopar/poly-graphics.htm
http://www.mascotgraphics.com/poly_318.htm
Here's typical comments from the "knowledgeable guys" at CarCraft, comments which have done much to perpetrate the myth that these engines were boat anchors. Even I didn't know better for a few years.
http://www.carcraft.com/techfaq/116_...de/index2.html
snowtrooper1966
Nov 20, 2013 06:39 PM
67II
Sep 2, 2009 04:33 PM
fpereira23
Feb 9, 2009 09:04 PM
LittleSpark
Jan 15, 2009 09:06 PM
Branden
Jan 8, 2009 08:01 PM
