'94 318 to '98 360....
Old 03-10-2009, 03:27 AM
Both motors are magnums so the ECM's pinout should be the same. The tranny is a hydralic shifting 46RH so it should be good with the stock 360. everything is the same between the motors so everything should just bolt right up.
You've got a pretty easy swap going right there.
Old 03-13-2009, 02:08 AM
I completely forgot about the OBD. As long as you have the wiring harness though, you should be good. if not then you may need to rewire the connectors and you will need a pinout to get it right.
Old 03-15-2009, 04:29 AM
No problem. Amytime you have a question post it up. Trucks are not that big at this forum but there are a few guys here that know something about them. Have you tried Ramcharger,com (i think that's that it is). They deal with a lot more trucks in a day than we do in a year.
Laura Cullen Reynolds
04-22-2024 03:24 AM
jej
11-17-2014 07:59 AM
notta _mech
09-13-2011 09:42 AM
keith811
01-13-2011 10:43 AM
choelzer
02-29-2008 03:00 AM
Quick Reply: '94 318 to '98 360....
