440 or 340
Old Dec 16, 2007 | 09:53 AM
Sounds to me like you are on a limited budget.
Consider a 360. The only issue with a 360 is, some (out of trucks) had rear sump pans, so you'd need one with the correct pan, or get a front sump pan. Your 318 pan will NOT fit a 360
Also, 360's are externally balanced. That means you need the proper flywheel with a stick. In the case of an auto, I'm not sure if the weights for the 360 are on the flex plate or the converter. Of course stay with the 360 front balancer.
If you buy a junker, and get a matching transmission, then your balance troubles are solved.
Other than that, it's a drop in for your 318. Many of the speed parts, manifolds, cams, intake, etc, will fit the 360. the only real issue again, is balance, and the pan.
The other thing about a 440 is the REST OF THE CAR.
All lower end, smaller engine cars were produced with worse brake, suspension and axle systems than the higher performance cars. You probably don't have a (any?) front sway bar, lighter brakes, at least in the rear, no posi, and certainly lighter torsion bars. THERE IS a difference between the "big" engine cars.
71mopar
Jan 31, 2013 10:13 PM
advracing
Jan 14, 2011 05:22 PM
Zach8200
Jul 11, 2010 02:28 PM
