318 engine swap in my 66 coronet
Old Dec 18, 2007 | 07:06 PM
I don't know if the engine mounts will fit. If not, you will have to round up the mounts and "mount to engine" bracket for a '67 318
The bellhousing is the same. You will probably use your old transmission, if it's in good shape. The 'new' trans should work but may be the wrong length
I hope you have exhaust manifolds for the "new" 318, and you may have to fiddle to get exhaust to fit. If the engine came with a "y" pipe, you are probably OK
This should be a pretty simple swap. the wiring should hook right up. There might be minor differences--I don't remember where the oil sender is on the old engine, so the old wire might be too short, etc
Either "new" or old starter should fit.
I don't remember, but I think you'll want to use the old converter "flex plate."
What did the "new" engine come out of? Some pickups had rear sump pans, and you'll want a front sump pan.
dr_riedel
Mar 21, 2011 01:26 PM
SfloreS
Jun 21, 2010 12:08 PM
mlithgow
Nov 26, 2008 02:15 AM
1982dodgeram
Nov 23, 2008 02:42 AM
ProEmaster
Jun 6, 2007 11:31 AM
