fuel starvation
Hi, excuse me my bad english. This is my problem:
I have a 318, weiand intake, 274 comp cam XE, Crane Hi6 ignition, mechanical factory pump. I start the engine with no problems.. when the car get the temperature (around 80 C) and after a run at full throttle. The car stop, i have a fuel filter between the pump and the carb and in the filter i dont see fuel. I let rest the car for 10 minutes and the car runs but only for a little time. I check the fuel pump: the valves and diapraghm are ok. The tank has gasoline. The next day on the morning the car runs without problem again and the fuel filter looks full of gasoline.....
Any ideas?? Thanks.
