upgrading a 318 on a budget
Guest
Posts: n/a
Alright guys im a full time ASE cert tech but have NEVER worked on carbs before, so i bought a 82 ram with a 318 to get a taste of a good old carbed engine, the engine that is currently in the truck has bad valve steam seals, and its giving me a little of trouble when its cold, it will stay runing if you rev it just a bit but after it warms up it wont die BUT when you give it too much gas it will die as if it had too much air going in, whats funy is that if you play with the pedal i'll even burn out.
i have another motor out of a 85 ram charger that has under 100k milles and ran perfect before i pulled it.
I'd like to use the newer engine on the pick up after doing some work to it.
I've been reading and trying to figure out what parts i should buy to upgrade the old teen before installing it.
I'd like to get close to 400hp keeping in mind that this truck is a daily driver and gas prices.
this website has all the info of what i'd like to do to the engine, please let me know if this set will be good for a daily driver or if its more than i need.
http://www.hotrod.com/howto/113_0304...ild/index.html
Thanks in advance!!!
Hot rod mag is pretty good about their tech stuff. If anything, I'd sell both 318s and start with a 360. You get more out of it doing the same stuff and it will cost you about the same as a 318. They are all over the place. heck a guy with a 360 motor in his 80s-93 truck might be willing to trade with you.
Do you plan on making this truck work at all for you? if so then keep the 318.
Guest
Posts: n/a
see thats the thing everyone has 360's fixed up and i really wanna go with a 318
I have 3 complete 318's i can use, the one out of the 85 ram cahrger is in such good shape it would be a waste not to use it, and yes i'll probably do some light hauling, and pull a boat with it a couple of times or maybe some jetskys...
Here is what I would do. Pull the motor that you have and throw in the good one. Then rebuild the one that you pull out how you want. You will have to bore the motor to get 400HP but there should be plenty of sidewall clearance. I wouldn't bore the motor unless you have to though. If you want reliable, then maybe look into a TBI setup instead of carb. If you go carb, get one with an electric choke.
You may also want to upgrade the tranny some (valvebody, shift kit, torque convertor). Don't forget about the rear axle also.
Senior Member
on
ported and polished *302 heads with 2.02 intake valves and 1.88? exhaust valves (should give you a 11 to 1 or better compression with flat top pistons, cam, flat top pistons, small 4bbl carb. if you are going to use it off road id go with 500 cfm or smaller. bigger carbs seem to make you lose torque. headers...
Guest
Posts: n/a
I'm willing to do work on the heads, but as far as the block goes i dont think i wont do more than freshening it up with new rings and rod bearings,
please tell me what carb has an electric choke or what tbi set up would be easy on the pocket and to install, i really want a carb i'm sick of working on efi and tbi engines at work
Senior Member
on
tbis are quite expensive for the conversions. just go on summitracing and you can narrow the search between electric and manual chokes. probably just an edelbrock performer 500cfm
Senior Member
on
but you probably arent going to get around 400 without boring it out. i would go .020 or .030 just in case you decide to rebuild it in the future and it needs another rebore. im in the process of rebuilding a 318 and one thing i did was use a dremel to bore out all of the oil pathways to provide better flow. soon its going to a shop to get rebored probably .020 over then getting the forged 340 crank
Guest
Posts: n/a
i dont wanna spend money on the block b/c that alone will blow the budget. i just said 400hp b/c thats what the number they achived on the website with just 1500 dollars.
tomorrow im gonna check the motor out of the ramcharger to make sure the heads are 302 castings, any tips on how to tell?
MoparMania-no cure for it
on
Great article from Hot Rod, lots of good info there..
But remember - you won't get those HP numbers unless you work the heads like they did,
and I wouldn't think the Edelbrock AirGap manifold & 1-inch carb spacer would be what you'd want
for towing & hauling purposes..
I'd say follow their build but forget the AirGap mani & carb spacer (and make 375 HP at the flywheel -
not too shabby!!! and a huge step up from where you are now).
Just don't over-carb it! or you'll have a total slug on your hands.
I wouldn't put anything bigger than a 600 cfm vac secondary carb on it!
You have the 318's, so use the 318's
(Murphy's Law predicts you will fall ***-backward
into a 360 shortly after you finish the 318 build though lol).
But so what? 318's can indeed make good power!
and get respectable mileage when tuned & set-up correctly.
318's were never really marketed as true "Hi-Po" engines back in the day,
and then the de-tuning for emissions
really seemed to cement their reputation as "dogs"..
But if you ever drove an old ('67 - '71, IE: Pre-Emission) 318, you'd know that even in stock trim
they make a surprising level of power and don't mind revving,
even w/ the restictive heads, and they really wake up once you let 'em breathe
thru a small 4 bbl & low-restriction exhaust..
Speakin of exhaust, forget the typical "cherrybomb"-type of straight-thru glasspack -
they sound great, but beleive it or not, have more back-pressure than you think
(thus robbing power - dyno tests prove it).
For a far less restrictive exhaust set-up, run a set of old Cadillac resonators (mid '60's thru late '70's)
- not the mufflers, just the resonators. And be sure to have a crossover pipe (H-pipe) in the exhaust,
for more "free" HP and torque.
The above exhaust set-up not only frees up power, but sounds great as well - deeper-toned,
but not obnoxious lol (and run a clutch-fan too, for more "free" HP)
There's my 2 cents worth on it lol..
Good luck with your build!
on
X2, I agree..
the following combos could work for your 318 -
Option 1
I found the following on the Summit Racing website:
Part Number EDL-2176
Intake Manifold, Edelbrock Performer, Dual Plane, Aluminum, Natural,
Square/Spread Bore, Chrysler, 318/340/360
$209
With either of the following carbs:
Summit Racing Street & Strip Carb
600 CFM Vacuum Secondary, electric choke, squarebore Carb
(Summit Brand Holley-type design)
$225
OR
Edelbrock Performer Carb
$300
Or
Holley Street Avenger 4160 Carb
670 CFM Vacuum Secondary, electric choke, squarebore Carb
(comes w/ different vacuum secondary springs for tuning -
different secondary springs will "size" it to your engine,
so don't worry about the 670 CFM rating)
$380
I listed the above separately because the Edelbrock Manifold/Carb
Combo Pack that Summit features comes with an RPM Air-Gap intake
and an 800 CFM Carb and lists for $875..
I still don't think you need that much carb/intake
for the way you intend to build and use your 318..
but senseless overkill can be yours for only 875 bucks lol
(just don't blame me if it don't run worth a damn lol)
If it were me, choosing from the above parts, I'd probably get the
Edelbrock Performer Dual Plane aluminum intake
and either the Edelbrock Performer Carb
or the Holley Street Avenger 4160 Carb.
I have experience setting up and tuning each type,
I think they're easy to work on.
The Summit Brand carb looks like a design copy of the Holley -
if so, it too should be very easy to set up & tune to your application.
Of course, you will need all the gaskets, fasteners
and other miscellaneous items to finish the installation..
Option 2 might be a Summit Racing Brand aluminum Intake & Carb
Combo Pack
Part Number Summit 03-0204
Summit® Intake Manifold, Carburetor, and Air Cleaner Value Packs
It includes:
Summit Racing Street & Strip® Stage 1 Intake Manifold
Intake Manifold, Stage 1, Dual Plane, Aluminum, Natural,
Spread/ Square Bore, Mopar, Small Block 318, 340, 360
And a
Summit Racing Street & Strip® Carburetor
PLUS all the gaskets & fasteners you'll need
And a chrome open element air cleaner..
$435
hmmm, all things considered, I might try this combo myself on my 318..
(though I prefer to run spreadbore carbs on my V8's)
Remember, no matter what you decide to get,
all carburetors perform best once they are set-up, tuned and tweaked
to your specific application (IE: Power Valve, vacuum secondary opening
point and rate, accelerator pump shot and volume, jetting,
position of throttle butterflies at idle, full linkage travel, etc).
Don't let any of this intimidate you - you may be satisfied with the way
it runs right out of the box -if so, cool.
If not, the new carbs come w/ info and there are plenty of books
and info online to help you set-up and tweak a carb..
Plus, the process itself can be very enjoyable
and very satisfying, in my opinion..
It's a great feeling to take a car that idles poorly or stalls or stumbles
or bogs out and turn it into a rocket, with strong, crisp, instant throttle response,
with the accelerator pump & power valves & secondaries all kicking in right on cue,
knockin ya back in the seat as the engine roars
and the scenery starts rushin by real quick..
aw man, the hell with sittin here at the computer -
I'm firin up the ol' Dodge & hittin the street !!
God bless America and Walter P Chrysler
If you hear a screamin V8 and smell tire smoke
don't worry - it's just me & my old Mopar
Option 1
$209
$225
OR
$300
Or
$380
Combo Pack
It includes:
And a
$435
Guest
Posts: n/a
well i have 2 good sets of 302 castings, i took one down to the machine shop for the guy to look at,
I think im gonna go with the Summit 03-0204 it seems the best bang for your buck...
And now the cam, wich one would make for a nice daily driver? i dont want lumpy idle to the point that you have to rev it just to keep it running, but i do want a cam that will make it run better than stock... what do you guys have in mind to complete the big 3?
on
Didn't the Hot Rod build suggest a cam (or so I thought)..?
In any case (and some may disagree)
but I have always liked to use a good-quality
double-roller timing chain/gearset,
and install a 2 degree offset key at the crank gear
(for 4 degrees advance at the cam).
Two reasons for this -
1) a little advance helps in the lower portion of the rpm/power band
(which i think you'd want since you say you plan to haul & tow
w/ the truck).
2) it helps compensate for the eventual wear and slack in the timing chain
No, the Hot Rod build doesn't mention doing this, but then they were
seeking ultimate top-end power, not real-life usable hauling & towing power lol..
A number of damn good old-school engine builders have told me about
this 2 degree advance trick over the years..
I've always done it & never regretted it.
Just more food for thought for ya
w/ the truck).
