exhaust flanges needed
Old Jan 8, 2008 | 04:57 AM
TCPMeta's Avatar
Junior Member
I have a set of shorty headers. At the collector it's 3 1/2". Saldy it's a 2 bolt flange.
Anyone know where I can get some flanges for it or know of a way to convert it to 3 bolt?
All I can find in 2 bolt is 3 inch and in overall size doesn't fit. 7 inch cross.
Old Jan 8, 2008 | 08:21 AM
Don't these fit right up to your factory head pipes?
Old Jan 8, 2008 | 01:47 PM
TCPMeta's Avatar
Junior Member
You might laugh at me when you hear this.
The headers are made for the Dodge Charger and Magnum V6 3.5L. I'm using these on a Dodge Intrepid that uses the same V6 3.5L. Thing is the exhaust systems are different so I have to fab two down pipes and add on two universal catalytic converters. The only thing stopping me is the flanges. The intrepid uses clamps while the charger and magnum uses bolt-on.
Old Jan 8, 2008 | 05:24 PM
I don't know. Have you contacted the header company?
Also, you might try contacting performance and muffler shops and see if someone pulled out a pair of stock exhaust, maybe you can get some head pipe stubs.
Other than that, you might have to cut off what's there and "start over"
If you can't weld, a good muffler shop should be able to install more common flanges--header type.
hckrphil
Jun 2, 2014 09:11 AM
plymouthrr1985
Oct 17, 2008 03:16 AM
J Dog
Jun 26, 2008 07:10 AM
LanceFury
May 27, 2008 12:33 PM
steelyblue
Sep 12, 2007 06:48 PM
