View Single Post
Old 01-08-2008, 05:51 PM   #2 (permalink)
Commando
Senior Member
Commando's Avatar
Did you check the fuses, if you have an amp meter check the wires connected to the battery and see if there is any draw as you could have a short. Other than that I would check the wiring to make sure nothing is loose or cut.
Commando is offline   Reply With Quote
