Antifreeze leak
Old Jan 12, 2008 | 05:08 PM
Originally Posted by 440doba
leak from the power steering pump to block bolts/ bolt. Dont know which bolt is leaking and I know there are alot of bolts that enter water passages....but the PS pump?
Are you saying you get oil or PS fluid IN THE COOLING system?
There is no possible way.
You could have engine oil leaking into the cooling due to a leaking gasket or crack somewhere in a head or block
You could have automatic trans fluid leaking into the cooling via the transmission cooler.
There is no possible way that you are getting a leak from the PS into the cooling.
Speedracer44
Mar 17, 2012 07:09 PM
66coronetgirlie
Aug 9, 2010 10:41 PM
macevanscb
Mar 8, 2010 03:10 PM
angel383
Mar 4, 2009 06:12 PM
wheelman487
Jan 3, 2008 08:54 PM
