383 vs 400
Old 05-05-2009, 04:54 AM
rr69half6bbl's Avatar
I think 400`s always got a bad rep. I had 1 in a 70 runner, wasnt a super bad motor but it ran great w/ 3.91`s and an automatic. main thing was it was a great street motor and super dependable, I drove that car everywhere. Id stay away from a solid lift cam for the street, alot of tuning issues, a good mid range cam with at least 750 cfm, for the trans , I think the new overdrive gear from passion for a standard 4 spd, would be nice, then you can run the 4.10`s and still have a decent driver. the nicest thing to me about using the 400 is you can still find them in junk yards , most of the 383 cars have been crushed already.
Old 05-05-2009, 12:02 PM
scotts74birds's Avatar
I've been checking this for myself. 440 source and Muscle motors seem to have some great kits for the 400. I really like the 496 stroker kit for the B block. I thought I read where the 400 is actually more rigid than the RB block?
Old 05-05-2009, 02:02 PM
i dont think so
the rb has more meat
i am pretty sure
Old 05-09-2009, 02:38 AM
Polaradude's Avatar
The 400 is a great block, it's the sleeper of the mopar world, there's lots you can do to them and they are still cheap. Great bang for your buck.
Old 05-09-2009, 11:40 AM
Polaradude's Avatar
Do it, I suspect your looking at the 440 Source stroker kit, reputable company with good stuff. The 400 has the biggest bore going, there's no replacement for displacement.
Old 05-13-2009, 02:45 AM
Polaradude's Avatar
With the complete kit comes crank etc etc. Why turn down/ruin a 440 crank. There are many schools of thought on that. I have concerns with removal of the nitriding on the crank conversely weakening the crank. The 440 Source kit has the problems worked out for ya, in the end it's your choice, but with the kit there is minimal f$ckin' around. Keep us posted bro.
Old 05-22-2009, 06:09 PM
deadkelly's Avatar
the low deck is a bit more sturdy & ridged because its shorter & so is the con rod . just like a short stick is harder to break than a long one ..
i think 400 is the way to go , do they have cast cranks ? 383 have forgies . it's the aftermarket cranks & light weight pistons that really make the low deck shine . lightweight rotating assemblies & valve train allows for quicker acceleration & strength & less hp taxed from friction ( shorter piston ) better rod ratio , less stress the list goes on . the 451 or 400 may be better suited to a abody or light car & use rpms . 440 + cid for b body's heavier cars . because they will all make the same hp is determined by your heads . cubic inches determines the rev range where you make your power . you just need to rev your 383 / 400 harder to make the same power as a 440 - 451 - 496 they all use the same heads .
Old 05-22-2009, 06:28 PM
deadkelly's Avatar
lightweight pistons & pins & compression or 440 rod ratio would help with weight to stroke issues .
Old 01-14-2012, 01:34 PM
Garys69RR's Avatar
Is the lighter piston the main advantage to a 400 stroked and bored to 451, over a 440 bored to 451 C I? Why does the low block make more torque than than a same size R B 451?( If it does).
Old 01-14-2012, 06:06 PM
Look into the 451, you'll find that the bore stroke ratio and primarily the stroke rod length ratio make it a excellent combination that can rev well and make tons of power. If you go that way look at pistons with a full lower ring land for the oil ring, some have smaller pins to accomplish this and will make a lighter piston pin combination.
Old 01-15-2012, 08:34 PM
Garys69RR's Avatar
Yea I noticed the K B 280 pistons @ 550 grams have the top of the pin protruding into the oil ring land. What type do I use for a full oil ring land? The KB 236 pistons for the 440 weigh 775 grams. So saving 225 grams of reciprocating weight times 8 = 1800 gram savings. At 6000 RPM that weight is changing direction 200 times a second! Thats 100 Revolutions a second, once up once down, right? Thats got to be a big power saver as well as less stress on crank, rods, and main bearing web. Think I will go with the 400 stroker.
Old 01-16-2012, 08:07 AM
Originally Posted by 67 GTX
i dont think so
i am pretty sure
Some like them and some don't but they have a good write up on blocks.
http://www.440source.com/blockinfo.htm
Old 01-16-2012, 09:37 AM
69POLARA383's Avatar
Exactly, 400 blocks can hold far more hp/tq than any other STOCK OEM block can! Bore it, stroke it, juice it!
1968newport
01-01-2013 12:59 AM
4004speedrunner
12-09-2012 11:43 AM
joel
02-22-2009 06:58 PM
CLJohnny
12-12-2008 11:45 AM
Dartin'
01-03-2008 05:28 AM
Quick Reply: 383 vs 400
