carb trouble
Old Jan 27, 2008 | 07:34 AM
First, I don't know where you are located, and how cold the climate is, so that may have a bearing.
Next, 72 was "starting" to be the "pain in the a##" years of smog control. Chrysler, instead of using smog pumps, like GM and Ford, played around with things like cam timing, ignition retart, and leaning out the carb to meet smog requirements. By about '76 they had leaned things out so much, that some of these cars were very poor to drive on cold startup--'specially in winter.
Further, you need to try and "figure" whether you actually have something wrong with the carb--IE dirt or corrosion, and these carbs are getting OLD--or whether this is typical from "smog" settins, or whether maybe you have ANOTHER problem, which can be---
The choke may not be operating properly, or set wrong
The idle screws may be set improperly, or the idle passages partially plugged
The accellerator pump may not be working correctly--the pump "leather" may be worn and stiff, or again, corroded or dirty pump discharge passages
Generally, the cruise and power circuits may be suffering the same fate
It's been a long time since I've followed the replacement carb situation. I would NOT go out and buy a factory "rebuilt" carb. I would investigate either
cleaning out (with chemicals) your present carb
investigate an aftermarket "street" carb
I would NOT put a "street/strip" or "race" carb--you mentioned 4 bbl--such as a "double pumper. These sound like driven cars, and you'd get horrid mileage.
The problem with putting 4 bbls one these, is that you'll have to change the manifolds, forget adapters, and you'll have the same problem. What to do for a carb? You haven't solved anything.
If you are not faced with yearly smog certification in your area, I'd look for a clean '71 or even '70 down to about '68 carb, clean them up, and use them. I realize that FINDING such a thing might be tough.
If it were me, I'd check with Edelbrock/ Holley/ Carter for replacement carbs.
SixtySevenDodge
May 18, 2012 02:55 PM
northcoasttip
Sep 26, 2011 11:23 PM
scampdude
Oct 20, 2008 06:06 PM
71RR08
Aug 14, 2008 07:36 PM
slow70duster
Jun 29, 2007 02:55 PM
