gas prices crunchin cash_time for TBI?
Old Jan 29, 2008 | 06:19 PM
You say, "the mileage is killin me" but you don't say what it IS.
Back when I swapped a stock '71 340 into my '70 body, it could get (on the highway) nearly 19 part of the time, it was
'70 Plymouth RR body, 3.54, Dana rear, G-70 x 15 tires
Stock '71 340, with headers.
Ran either stock Themojunk Carter, or GM quadrajet carbs, and for awhile, ran Holley "spread bore." Best mileage was with a Quadrajet!!
Just about any good running, properly tuned 318 should be able to get more than 17, if you drive responsibly, and there is nothing wrong with the engine, and have something for "street" gears.
Old Jan 30, 2008 | 09:49 AM
That's true, and trying to adapte a TBI is NOT the "magic bullet" here, and might just cause more problems.
There are MANY things besides the carb and intake which affect mileage.
Run a good hot 190 stat
Make sure the engine is running "up to temp" but not overheating.
Make sure your tires are not underinflated.
Check out your gearing / tire combo. Usually, higher ratios (lower engine RPM) helps with mild street engines, but in some hi perf. cases, if you get "too low" the engine can actually get worse mileage
Check your ignition advance. Is the mechanical advance working properly, and advancing all the way?
Ditto the vacuum advance. Is it working, and is it hooked to the proper vacuum port?
And, of course, there's your driving habits!!!
marty mopar
Oct 8, 2014 12:38 PM
66 valiant Paul
Nov 16, 2012 05:17 AM
bennersaw
Feb 18, 2009 05:48 PM
Doc
Nov 30, 2008 05:09 PM
tbreaden
Jan 20, 2008 02:18 AM
