CAR WONT START????
Old Feb 5, 2008 | 08:06 PM
Could be a number of things.
Did you pull a couple of plugs and see if they are fouled?
(Getting too much fuel)
How do you know it's getting fuel?
How good is the spark?
Take a "solid core" wire and replace the distributor / coil wire, then crank over with the temporary wire and see if you get a good fat spark at least 3/8"
How about time? Is it possible that the timing chain slipped? Do you have a timing light? Can you crank the engine and see if you can time it while cranking?
If not, answer back, and I'll tell you how to "static" time the engine to check
Also, if it's trying to fire, but blubbering and smoking, find something like a screwdriver, and block the choke open.
Old Feb 6, 2008 | 08:43 AM
Before you play with the timing, think a little.
What do you mean, "cause the carb is already set to high"
If the plugs are wet, you have probably found the problem--You are probably flooding it. If only three are fireing, it probably shows you that either you are flooding the engine, or your spark is really weak.
Have you checked the spark as I asked?
Get some dry plugs in there.
Old Feb 6, 2008 | 05:45 PM
I'm not entirely convinced you are not flooding the engine, especially since you elude to have had carb trouble earlier.
However, you might want to try and check the timing.
With a points system, this is easy. Get the timing mark "up" about TDC and put either a test light or multimeter (voltage) across the points. With the key on, slowly wrench the engine forward, until the lamp lights or the voltmeter shows voltage. At the instant this happens, stop with the wrench, and look at the marks. You should be somewhere close to the timing mark.
Also, if you suspect the cam timing "slipped" --almost ALWAYS due to a fiber top drive sprocket-- also 'wrench' the engine CW and CCW and see how much "play" there is before you see more resistance, which shows slop in the chain.
Old Jun 22, 2008 | 09:42 AM
ef8340's Avatar
Senior Member
maybe even weak valve springs
Old Jul 18, 2008 | 07:28 PM
challenger's Avatar
did you find out problem
If i were you and didn't find out the problem yet ? I would check to make sure you have the plug wires in the right order and if they are i would ( make sure you have a air cleaner on ) turn the engine over and turn the distributer clock wise to advance it just a bit and see if that fires her and if so and you have to go to much then what 440 said about the chain is correct but i think i would really check the wires first most of the time if it sounds like you have the plugs out when turning it over that sometimes means the wires/chain are wrong ,,,this is a old question so hopefully you have allready solved the problem
dodgenut7
Jun 24, 2011 06:51 PM
bengibbard13@gmail.com
Aug 10, 2010 05:41 PM
6865coronet
Aug 11, 2009 09:55 PM
shelbydz
May 9, 2009 03:10 AM
duster74
Feb 11, 2009 07:43 PM
