'68 Plymouth Valiant Signet, No spark, nothing.
Old Feb 13, 2008 | 08:31 PM
It is difficult to troubleshoot by remote control. If I was near you, I guarantee you that we could nail down the trouble in short order.
First, you need to (must) get a few very basic troubleshooting aids.
At the very least, go to Radio Shack and get a package of clip leads
Go to an auto supply outfit and at the VERY least, get a 12V test lamp. A much better plan is to not only get a lamp, but an inexpensive multimeter as well. In this day and age, adequate multimeters are VERY cheap, and sold almost anywhere that auto parts are sold.
Now, there are several trouble areas, ESPECIALLY now that your car is so old, rust and corrosion over time takes it's toll. The several trouble spots are (not necessarily in order)
The fusable link(s)
Any main connections on or near the battery
At least two major connections at the "firewall plug"
At least one factory splice taped into the main harness
The ignition switch
The ammeter connections at the back of the dashboard
In your case, you need to simplify your terminology, and state EXACTLY what you have and do not have, and use some common terms.
Start with the following:
Put a good battery in the car, and try to get the starter to crank the engine:
1 Make sure the car is in neutral (park)
2 With a screwdriver, short across the starter relay.
This will show you that the big main battery cables are good and the battery has good connections
Now see what you have for power:
1 Any interior light?
2 Turn on the ignition
Anything, radio, wiper, heater blower?
If not, then you do indeed have a problem with one of the major areas I listed.
Take your test light or meter and make SURE it has a good ground. us your test clip to the block
Probe on each side of your "damaged" fusable link with a good sharp probe, either using the meter or your test lamp
You should find power on both ends, by cutting into the insulation. You should be able to buy replacement fuse links that can be spliced (crimped) onto the wiring Places like NAPA should have or be able to get them
If you don't have a diagram, you should get one, very important. If not, you might just have to untape part of the harness.
Probe the large nut connection on the alternator. This should be hot at all times--not affected by the ignition switch.
Pull the dash out far enough to inspect the ammeter connections. Do this of course with the battery ground removed. When you get the dash out a little ways, hook up the battery, and with the light/meter grounded, probe the ammeter connections. BOTH should have battery voltage at all times. Wiggle them, inspect for any looseness.
Determine which connections in the firewall connector carry the ammeter wires. Probe these and make sure they are hot at all times.
Your problem (at this point) has nothing to do with the fusebox, because the ignition system does not go through the fusebox.
However, if you have power at different places in the fusebox, but the car won't crank or start, this might indicate a problem in the ignition switch, either a loose connector/ corroded, or a bad switch.
Here's an engine compartment diagram I found online:
http://www.valiant.org/electrical-diagrams.html
Some diagrams for a '64, which should be pretty close:
http://kim_spure.tripod.com/wiring-d...-valiant64.htm
slimjimd
Apr 1, 2011 11:17 AM
slimjimd
Jan 31, 2011 03:24 AM
Coolio9
Aug 20, 2009 06:24 PM
Coolio9
Aug 5, 2009 04:40 PM
AlexMacTools
Sep 1, 2008 01:42 PM
