1986 Dodge Ram Truck
Old Jun 13, 2009 | 01:05 PM
Are you checking the wires while the ignition switch is in the run position? That is the only want that you will get power to it.
Old Jul 2, 2009 | 03:39 AM
pic of it might help us out help you. I can't picture it in my head. Also where about is it behind the dash?
Old Jul 2, 2009 | 11:14 AM
I remember my 82 D100 having a 7 pin flat connector that plugged into the radio.....
Are the wires 18 gauge or are there some larger ones (red and yellow wires)? could be for teh ignition switch.
Old Jul 2, 2009 | 07:04 PM
scotts74birds's Avatar
What doesn't work now?
Old Sep 3, 2009 | 09:32 AM
crwchf16's Avatar
Most car manufacturers of the time (and now) will put a generic wiring harness into a car that will fit whatever trim package they are installing. Does your plug have dust or corrosion on the face of it? If so then it hasn't been plugged into anything for a long time and you need not worry about it. Otherwise go with scotts74birds suggestion and see what doesn't turn on anymore.
Good luck!
customaesthetics
Aug 7, 2012 06:13 AM
pinon1
Dec 10, 2011 12:35 PM
bzirk
Nov 21, 2011 02:18 AM
Nw360Dodge
Nov 19, 2011 04:27 AM
hypermite
Mar 13, 2009 03:16 PM
