Yep, if you don't have flash on the green, it's probably the switch, but to be sure, now check at the connector at the switch. I don't remember exactly where this is, but there may be a "spash" panel directly under the column. That's the one I itemized for color.
You need a "steering wheel puller" which should be available at any parts store. Make sure that the bolts include "American" bolts--these are not metric, and some new pullers come that way.
