1964 -318 auto swap?
Old 07-01-2009, 04:52 PM
You know, that is the one thing I am not sure of with the poly blocks; if they have the same bell housing as an LA motor. If they do then you will want a 518a tranny (late 80s-early 90s before 94) for an auto.
Old 07-01-2009, 04:55 PM
theomahamoparguy's Avatar
Originally Posted by avaianas
Hi
is there a 4 spd auto that'll fit a wide body 318 in my 64 truck? Or.. can I put a 4sd/5 spd (overdrive )manual in? wWhat's involved.
Thanks, Jim
Well the wide 318 has the same boltpattern as the newer 318 so any thing that fits a regulaR 318 will fit the wide [polysphere] 318.
An a500 or a 518 will bolt up [not sure if any electronics are involved]
Another option would be an overdrive 4sp [Manual}
Old 07-01-2009, 04:57 PM
Thats good to know
Those autos are hydro shift, no electronics...that I know of and have seen.
Old 02-08-2010, 08:51 PM
Member
volaredon's Avatar
only up tom 95. 96+ they went electronic and though otherwise teh same trans they changed the names to the "RH/RE suffixes. Previous to 96 became known as "RH" (RWD/hydraulic gov) 96+ "RE" means RWD electronic gov. 42,44 RH?RE are what used to be called "A500" (904-based) 46, 47 RH/RE are what used to be known as A518 48RE (diesel only) is what they used to call "A618".
Fwmoraes
12-05-2019 04:45 PM
mrwillys
01-09-2014 04:19 PM
mikeceli
12-10-2010 04:38 AM
YellowDodge67
07-01-2010 12:47 AM
mrblond750
06-23-2010 05:55 PM
Quick Reply: 1964 -318 auto swap?
