nice build bad advice
Old Mar 4, 2008 | 01:42 PM
Factory 383hp and 440 heads were essentially the same, at least for a few years, so I doubt that the valve size is a problem
It may be more likely that the cam is way too big for what you want
Can you post some more specs?
Weight of the car? (and model)
Transmission, rear gear ratio, and tire size?
What RPM do you see at a true 60mph?
Are you running headers? a good free flow exhaust?
What is the EXACT model and specs on the cam you are running?
For example, if you took a fairly stock 383 with factory manifolds, and put in a big, 300deg, .5 lift cam, it might actually SLOW THE CAR DOWN from stock!!
1967_coronet500
May 7, 2010 11:00 AM
rcknrolfender79
Dec 3, 2009 09:39 AM
rcknrolfender79
Nov 29, 2009 02:07 AM
Fury IIIski
Sep 14, 2009 05:11 PM
dand97
Apr 13, 2009 08:14 AM
