First, I'm not familiar with this manifold, but there is some mention around the 'www that it's made in China, and that evidently some folks are getting poor quality control.
However, I don't understand where the leakage is. The only coolant present is the very front and very rear "ports" on the heads, for example, wehre the threaded hole is clear up out of the picture at top left.
Now, if you are referring to the uncovered hole in the middle top of the pic, near the carb, that is the head crossover casting, and has an "inner" hole that IS covered, so the uncovered hole near the carb is OK
Where is the thing leaking?
