how warm is running too warm?
Old Mar 14, 2008 | 01:18 PM
First thing I'd suspect is that the gauge reading is wrong.
These cars are getting old, and anything can happen
There's an "instrument panel regulator" up behind the panel that feeds the temp, oil, gas gauges reduced voltage. These can go bad.
The gauge itself could be innaccurate.
Are you sure that the sender is the correct one? Even if correct, it could be bad.
Try and find something to measure temp, if nothing else, find a cheap HVAC or meat thermometer and tape it to the side of the top hose. Wrap a rag or two around it to insulate it
The difference in the manifold should not make a difference.
Old Mar 14, 2008 | 03:53 PM
If it's overheating, the radiator should be building lots of pressure, unless you have a bad cap or leak somewhere
Are you saying the heater does NOT put out heat? That's a bad sign. Is there any chance you have an "air lock" in the cooling system? Both heater hoses should be warm, and when the stat opens and the engine warms up, you should see circulation in the radiator. Top hose should be warm/ hot, bottom almost as warm. You might not be able to tell the difference.
Old Mar 14, 2008 | 07:10 PM
OK, so we've determined that it apparrently NOT oveheating, and the heater works.
I would first replace the temp gauge sender and see what happens.
gyates93
Mar 9, 2023 02:36 PM
Route66rider
Jul 26, 2012 08:24 AM
sgp7679
Apr 25, 2009 11:44 AM
theaspenator
Feb 1, 2008 07:46 PM
ucfierocharger
Nov 20, 2007 07:16 AM
