View Single Post
Old 03-14-2008, 04:53 PM   #4 (permalink)
440roadrunner
Senior Member
If it's overheating, the radiator should be building lots of pressure, unless you have a bad cap or leak somewhere
Are you saying the heater does NOT put out heat? That's a bad sign. Is there any chance you have an "air lock" in the cooling system? Both heater hoses should be warm, and when the stat opens and the engine warms up, you should see circulation in the radiator. Top hose should be warm/ hot, bottom almost as warm. You might not be able to tell the difference.
440roadrunner is offline   Reply With Quote
