How your neutral safety switch works:
Start with the firewall starter relay. The older stick shift cars had only one "pull off" connector on the firewall relay, which went to the "start" postition on the key. When you twist the key, the switch feeds battery to this terminal and engages the starter relay.
The auto's add a SECOND "pull off" terminal on the starter relay. This wire goes to the neutral safety switch, which GROUNDS this wire WHEN IN neutral or park. Therefore, if you unhook the neutral safety switch, the car should not start.
The other two prongs on the neutral safety switch operate the backup lights.
If your car starts without the switch hooked up, either someone has grounded the wire, or it is shorted, or someone has replaced the relay with a "stick" shift relay.
Here's a picture of an "auto" relay. Also, starting in '70, stick shift cars had a clutch pedal switch so that you had to push down the clutch to operate the starter, so '70 and later 'stick cars used the same relay as the auto cars
