1966 Plymouth Valiant Signet
Old 08-05-2009, 06:05 PM
theomahamoparguy's Avatar
If you gowith the 73-76 dart/valiant setup, make sure you get the upper control arm with the setup [from the 73-76] the newer setup uses a larger upper ball joint. If you find them impossible to remove {they can be a B*tch}, you can get new ones from Master Power Brakes.
Old 08-20-2009, 06:20 PM
Junior Member
phish1270's Avatar
Scarebird
There also is a company called Scarebird that makes disc brake conversion kits for drum brake cars. They offer a bracket that will bolt onto your drum brake spindle, preferably 10" drums I think. Then you buy Celebrity calipers & rotors along with Cadillac hoses, all pretty cheap. This is obviously not for diehard Mopar purists but it is the least expensive option. There are a few write ups on FABO. It also looks like the easiest to do.
Old 08-20-2009, 06:24 PM
I never noticed that this is an old thread {original post} from 2007.
Oh well
slimjimd
04-01-2011 11:17 AM
slimjimd
01-31-2011 03:24 AM
Coolio9
08-05-2009 04:40 PM
AlexMacTools
09-01-2008 01:42 PM
Pfhoenix
04-03-2008 10:44 PM
Quick Reply: 1966 Plymouth Valiant Signet
