Dodge Dart Swinger bolt pattern
Old Apr 1, 2008 | 08:42 AM
Why can't you measure it?
http://kleenwheelsincolor.com/kwic_d...e_diameter.htm
Old Jun 15, 2010 | 06:51 PM
Flammopar's Avatar
If im correct, And i believe I am on this. The 73 swingers has the 5 on 4 hole pattern.At least my 72 and 74 swingers both had that pattern as well as my 64 and 65 darts.
Old Jun 15, 2010 | 07:17 PM
mopardrt's Avatar
73 is the last year for small bolt pattern wheels 74 starts the big blots
Old Jun 15, 2010 | 07:39 PM
Crazy4Carz.Com's Avatar
Depends on the powerplant.
Old Jun 20, 2010 | 06:27 AM
ef8340's Avatar
Senior Member
my old 73 swinger had small bolt rims on it from the factory and it was a /6 car with drums all the way around theres a 74 360 duster inthe wrecking yard close to me that has big bolt pattern i want to say that 72 was the last yr for kelsy/hayes 4 piston disc brakes after that they went to a single piston caliper in which is big bolt pattern i might be wrong but i think 73 is a switch over yr between small bolt and big bolt
Terry
Old Feb 8, 2020 | 08:45 PM
Dennis Dennis's Avatar
1973 bolt pattern
i have a 73 dart swinger built 7/73 .... slant 6, w/drums all around..... 5 x 4 1/2
Old May 19, 2021 | 04:18 PM
Mopar5x21's Avatar
You dont happen to know where there is a set of hubs/drums like yours (FRONTS) do you? I am trying to keep my drum brakes on my 69 dart, but need to go to the 5 on 4.5 bolt pattern so i can change wheels.
EduardoIbarra
Oct 16, 2017 04:43 AM
Swingermike
Feb 1, 2014 06:35 AM
ThomasNieman710
Jun 7, 2013 10:04 AM
Shrug
Jan 22, 2013 01:55 PM
scott2683
May 3, 2010 06:31 PM
