No Ignition 225 Slant 6 PLEASE HELP!
Old Apr 13, 2008 | 11:14 AM
Your question is unclear. It sounds like you are not getting an even, rythmic spark? This could be caused by wear in the dist. shaft bushings, or maladjustment of the reluctor-to-pickup gap, damage to the reluctor or pickup, or foreign magnetic material---iron--stuck to either one.
Best way to check is pull the coil wire, and rig a gap at the end, like a spark plug. Then crank, and you should get nice, rythmic sparks.
Why did you initially replace alll this stuff?
Also, and especially now that so many things are imported, buying a new ECU does not mean it works. Did you buy this from a "brand name" parts store?
uponone789
Sep 28, 2012 03:48 AM
cmetzbower
Oct 11, 2010 12:27 AM
1966DartConvertible
Aug 6, 2010 09:03 AM
carburetor472
Sep 2, 2008 09:15 AM
hatboy2002
Jun 18, 2008 10:05 AM
