Wiring problem?
Old Apr 21, 2008 | 04:19 AM
fishpwr's Avatar
Wiring problem?
I had posted my problem earlier with my 70 cuda, but now it's taking a different course. When I hook the battery up the blinker lights in the front and back of the car light up instantly. Even the left and right arrows inside the car. I've replaced the flashers and looked at all the wiring that is visible and it all looks good. I'm not sure why the blinkers have a constant power going to them. I started the car and left it running for awhile and the alt. was taking a negative charge. After about 5 minutes the alt. gage went as far on the plus charge side as possible. I've unplugged connectors and reconnected them and still no luck. Inside the car, under the steering wheel, there's two connectors, one is the power source with the red wire and the other is for the blinkers. If I unplug them both and hook the battery back up, the lights still turn on. When I'm under the hood and unplug the connector with the red power source that's on the firewall, then hook up the battery, the lights do not turn on. Any ideas?
Old Sep 22, 2008 | 08:06 PM
challenger's Avatar
its all in the ground and check to make sure no hot wires are grounding to anything see if the brake wire from the valve is melted from the exhaust and touching metal and to tank man check your rear light sockets , dodge had a problem with them corroding and not grounding so when you get home run a wire from the neg- side bat and ground to socket
Old Sep 23, 2008 | 05:31 PM
Commando's Avatar
I know we carry them in my friends store, they are not too expensive, but if you know what you are looking for they should be in other parts stores.
rc-ltu
Feb 8, 2011 09:00 PM
RROriginals
May 8, 2010 07:33 PM
skrewball1211
Dec 3, 2008 03:56 PM
dbaughman
Apr 5, 2008 08:53 AM
wtim47
Cuda Specific Discussion
Jun 8, 2007 04:51 PM
