MOPAR Distributor Help
Old Apr 22, 2008 | 08:51 PM
I used to have a cast iron "hemi" tach drive which I ran in my 440.
If you can't track the number, "spring" the rotor and see which way it goes. The BB engines rotate CCW, so if you can move it CCW, it fits a BB.
Then the second thing to find out is whether it's a long shaft--for raised block or hemi's, or a short shaft, for low blocks, like 383
If the rotor moves CW, it fits a small block.
I 'spose' there's some possibility it fits some early hemi.
Old Apr 23, 2008 | 10:07 PM
mr340's Avatar
the correct # is 3690201, it is a '73 RB w/tach drive. Fits auto and manual, all bodies w/factory RB engine Being a '73 unit would make it for a 440.
( RB: 383, 413, 426 Wedge (not Hemi), 440 )
Old Apr 23, 2008 | 11:22 PM
Actually, it should fit a 426 hemi, as well, and most 383's are not a RB engine.
Old Apr 24, 2008 | 03:34 AM
mr340's Avatar
'Tis true, but being a '73 part, the 383/426 were well out of production. I assumed he was looking for OEM install info, which can only be 440 for '73.
Old Apr 24, 2008 | 09:11 AM
ya but.......go back and read your own post.
First, I'm not sure your info is correct. I'm not aware that a tach drive dist. of that nature was factory in 73 440's. Is this an electronic igniton distributor? It doesn't appear to have a vac advance, therefore it would not have been OEM in 73?
Additionally, you posted what I quoted above, indicating that a 383 was an RB, and you specifically exempted the hemi, as if it would not fit.
Old Apr 24, 2008 | 08:11 PM
mr340's Avatar
Here is where I got the info relating to year based on supplied part #
http://lightningjar.com/mopar/partnu...stributor4.txt
Here is where I found the info regarding which motors (RB) it will fit, not necessarily what motor it is correct for:
http://www.yearone.com/updatedsingle...gineinfo4.html
http://www.yearone.com/updatedsingle...gineinfo1.html
the last one clearly states that the Hemi is not among the RB family. Hope that clears things up.
Old Apr 27, 2008 | 10:38 PM
You misunderstood part of what I meant. I understand what an RB is, I've owned a few.
What I'm saying is---IF this is a long shaft distributor, meaning it will fit an RB, IE 413, 426 wedge or 440--it WILL also fit a 426 hemi.
dreyerot
Dec 2, 2013 12:48 AM
Mr442
Jul 14, 2013 09:25 PM
shoreboy85
Aug 17, 2011 08:39 AM
Aspen
Aug 31, 2009 10:25 PM
valleyofthesuns
Sep 24, 2008 09:56 AM
