Thread: 318/390 Stroker
View Single Post
Old 01-30-2007, 12:06 PM   #4 (permalink)
1 Bad Mirada
Administrator
1 Bad Mirada's Avatar
unless youre set on a stroker, you dont need it if youre only shooting for 400rwhp. im running a .030 over 340 with 9 to 1 compression, small valve heads, good intake and carb...headers...and im making around 380 rwhp. that is with ported stock 360 iron heads, 1.88 intake 1.60 exhaust valves...528 cam, 1 5/8 headers. 3700lb car running 12.40s...imagine if i had a set of edelbrock heads, 2.02/1.60, same cam, high compression pistons, etc...there is no doubt that i would easily pick up 20 more rwhp. i think that the heads alone would do that...no need for a big stroker.
1 Bad Mirada is offline   Reply With Quote
