View Single Post
Old 04-27-2008, 11:41 PM   #2 (permalink)
440roadrunner
Senior Member
I'm not sure if the actual part was different or not. I CAN tell you this--there is very little difference in height between the B and RB engines. So far as fitting in the car, I doubt it will be an issue. You'd probably change the installed height much more with differences in manifolds and carbs, IE Carter vs Holley, and aftermarket vs factory manifolds
440roadrunner is offline   Reply With Quote
