Thread: 383
View Single Post
Old 04-30-2008, 06:07 PM   #10 (permalink)
Ph.D in wheelinology
Send a message via AIM to 78D200
i haven't built any mopar cars but i have built a truck or two. can't you build the 340 to push the dart into the 12s with spending the same amount of money or maybe even a little less.
I know that a well built 383 in a d series truck will get down into the high 10 to mid 11s. weight and the set up has some bearing on that, and i understand.
my point is, if you build the 340 not only should you be able to get into the 12s but it would be cooler with a small block.
__________________
Tim and Heather
1974 J10 - getting built up some more. built 360, built TH400, D300, D60(detroit)/14B(spool), SOA, inboard rear 64" springs, 38.5 thornbirds
jeep pics - http://s149.photobucket.com/albums/s63/jeeping1974/J10/
78D200 is offline   Reply With Quote
