View Single Post
Old 05-08-2008, 01:21 PM   #2 (permalink)
Ph.D in wheelinology
Send a message via AIM to 78D200
Quote:
Originally Posted by crioten View Post
what mopar perf. cam should i go with on this?
I can't help you out with the other stuff, but about the cam. what type of drive are you going to be doing? Do you have a stall convertor or a regular convertor in the tranny? That will make a difference when choicing the right cam.
I am basiclly going for the same setup as you with the exhaust, intake, carb and ignition, except I'm building a 78 d200 with a reman long block. Are you running an electric choke or manual on your carb?
__________________
Tim and Heather
1974 J10 - getting built up some more. built 360, built TH400, D300, D60(detroit)/14B(spool), SOA, inboard rear 64" springs, 38.5 thornbirds
jeep pics - http://s149.photobucket.com/albums/s63/jeeping1974/J10/
78D200 is offline   Reply With Quote
