Fuel pump frustration in a 69 charger-
Old May 12, 2008 | 09:07 AM
I would check the part number of the pump to be sure you have a correct pump. All 383 and other related BB engines "can" use the same pump, so if your pump has the right hose connections, and is supposed to fit a 361-383-440, etc, it will fit.
Have you bumped the engine over to get the pushrod "up" as far as it will go? I don't remember any issues with these, but it's been a long time. My recollection is, I put my finger or a scrap of plastic in under the pump rod, and either "bumped" the engine or turned the front nut with a wrench until the rod was "up"
Glue the gasket to the pump, ease the arm under the pump rod and push gently until the pump seats. It's easy to pull the alternator out of the way, so you should be able to see what you're doing.
sgp7679
Feb 11, 2009 06:02 PM
nailbender
Dec 6, 2008 07:11 PM
nailbender
Nov 27, 2008 09:20 PM
skymynx
Oct 21, 2008 07:15 AM
rapidride2
Mar 20, 2007 05:58 PM
