Thread: 1974 J10
View Single Post
Old 05-26-2008, 04:47 AM   #1 (permalink)
Ph.D in wheelinology
Send a message via AIM to 78D200
1974 J10
Well I figured since I have a 1974 AMC (Jeep) J10 pick up, I should post something about it in here. I've had it since 2003 and have been working on it since. I used it as my daily driver for a few months back in 2004 when I had to pull my tranny out of my dakota and rebuild it. After that I started to build it up for wheeling. It has an AMC 360 built, TH400 built, it had a qt case that I pulled and installed a dana 300 with clocking ring (hopefully soon i'll be able to install 32 spline outputs), dana 60 full floating rear axle out of a 79 J20, a HD dana 44 front axle out of the same j20 which will be getting pulled out so a chevy dana 60 SRW front axle to go in. The front suspension is stock leafs with 1.5" add-a-leafs and BJ's offroad lift shackles, the rear is 1.5" add-a-leafs and 1.5" blocks. I have cut the extended fender flares offs and have a set of 35x15x16.5 TSL super swampers mounted a do-it-yourself beadlock kit. The interior got gutted and 12 gauge steel went down for new floor boards, seats from an 03 jeep rubicon went it, I hand made the instrument cluster and replaced the shifter lever with a B&M sport shifter.
__________________
Tim and Heather
1974 J10 - getting built up some more. built 360, built TH400, D300, D60(detroit)/14B(spool), SOA, inboard rear 64" springs, 38.5 thornbirds
jeep pics - http://s149.photobucket.com/albums/s63/jeeping1974/J10/
78D200 is offline   Reply With Quote
