View Single Post
Old 06-03-2008, 05:50 PM   #6 (permalink)
Zach8200
Member
well theres allot you could do when i pulled my top off there was paint but there was also allot of glue from the vinyl top depending on how ruff the roof is after striping the vinyl you might just want to have it media blasted or sand blasted then put a thin layer of filler in the areas that is needed to make it look good then primer and paint and of course the sealer thats just a quick run through im sure im missing somthing but its all obvious once you get going on what you have to do good luck
Zach8200 is offline   Reply With Quote
