Im not certain about them being retro fitted, but a small block head will not fit on a magnum block...if they did, i wouldnt be running the junk stock heads on the Ram....and the aftermarket heads wouldnt be so expensive.
i think that as for retro fitting, it would be more work than it is worth, unless you know someone who works at/runs a machine shop, and even then, im not sure that its worth the hassle, or possible.
