1974 J10
Old May 26, 2008 | 03:47 AM
1974 J10
Well I figured since I have a 1974 AMC (Jeep) J10 pick up, I should post something about it in here. I've had it since 2003 and have been working on it since. I used it as my daily driver for a few months back in 2004 when I had to pull my tranny out of my dakota and rebuild it. After that I started to build it up for wheeling. It has an AMC 360 built, TH400 built, it had a qt case that I pulled and installed a dana 300 with clocking ring (hopefully soon i'll be able to install 32 spline outputs), dana 60 full floating rear axle out of a 79 J20, a HD dana 44 front axle out of the same j20 which will be getting pulled out so a chevy dana 60 SRW front axle to go in. The front suspension is stock leafs with 1.5" add-a-leafs and BJ's offroad lift shackles, the rear is 1.5" add-a-leafs and 1.5" blocks. I have cut the extended fender flares offs and have a set of 35x15x16.5 TSL super swampers mounted a do-it-yourself beadlock kit. The interior got gutted and 12 gauge steel went down for new floor boards, seats from an 03 jeep rubicon went it, I hand made the instrument cluster and replaced the shifter lever with a B&M sport shifter.
Old May 26, 2008 | 03:49 AM
Here is a list of mods that I have completed.
Edelbrock 600 cfm carb
Edelbrock performer intake manifold
Edelbrock valve covers
Trans-Dapt oil pan
urathane motor mounts
Energy Suspension urathane tranny mounts
custom tranny mount adaptor
custom tranny crossmember
Clevite 77 cam, crank, connecting rod bearings
chrome moly pistom rings
new forged pistons - 9.8:1 compression
1", 4 hole carb spacer
MSD standard pro-billet distributor
MSD blaster 2 coil
MSD 8.5mm spark plug wire set
Flow Kooler waterpump
K&N stubstack
K&N air cleaner
K&N exstream air lid
Powermaster XS power torque starter
Summit racing fuel cell, bed mounted
Summit Racing K8600 cam w/lifters
custom box around fuel cell in bed
B&M Hole Shot 1200 stall converter
B&M heavy duty shift kit
B&M race ready rebuild kit
B&M adjustable vacuum module
B&M tranny cooler w/ 6" electric fan
Autometer gauges/ new custom insturment cluster
16" electric fan for radiator
Hedmen headers
custom 2.5" exhaust ending right behind cab
2 Flowmaster 40 series mufflers
manual choke cable
tachometer
tranny temp guage
storage units mounted in bed for tools/parts
BJ Offroad 1" heavy duty lift shackles, front
Powermaster alternator
header wrap
Rancho 1.5" add-a-leafs front/rear
Superlift 1.5" lift blocks rear
Skyjacker shocks
03 Jeep Wrangler Rubicon seats w/custom brackets
cut fender flares off
Painless Wiring fuse panel
heavy duty dana 44 front
power trac locker
full floating dana 60 rear
locker rite locker
steering box brace
Old May 26, 2008 | 03:52 AM
This is what I have left to do to it before it is completely done.
4.56 gears, front/rear
either 39" Iroks or TSLs
front diff cover protection
dana 60 front axle, detroit locker and SOA
14 bolt rear welded
install chevy 64" springs under frame for rear suspension
Optima 31a battery
engine, transmission, t-case skid plates, 3/8 inch thick
front/rear driveshaft
12,000 pound winch
battery box
CV shafts in front axle
shave axles
remove bed and add custom bed with roll cage
Old May 26, 2008 | 03:56 AM
Here is a link to all the pics of the jeep. let me know if it works or not.
http://s149.photobucket.com/albums/s...J10/?start=all
Here are just a few:
Old Jun 25, 2008 | 01:21 AM
Well I picked up a set of 4.56 richmond gears for $210 yesterday and a Detroit Locker for $300 this morning, all for the front D60. Only reason why I'm not going with 5.13 gears like I wanted to is because the friend of mine that is giving me the 14B for free has a carrier and a set of 4.56 gears for it. No point in spending the extra money now just to change it.
Hopefully next weekend I'll be able to get the axles set up and maybe start to fit everything under the frame.
I did notice that one of my front springs has a slight bend in it behind the axle. Once I get the rear susension all set, I'll place the front axle in and see how see sits before replacing the springs. At least that way there I'll be able to see if I need to lift the front end up higher or not.
Also I'm picked up a 5'x4' piece of 1/4" alum diamond plate sunday night so the bed started to come off lastnight, which will make it easier to setup the rear.
Old Aug 18, 2008 | 01:06 AM
Well Heather helped me out today with appling a coat of primer to the frame after I cleaned it up. I was cleaned up the alxes, primed and painted them. I'll be able to get a lot more done once the ubolts, spring plates, diff covers, 4" front leaf springs, and shock mounts come in.
Here are some pics:
Old Aug 18, 2008 | 02:43 PM
Originally Posted by richinny
nice progress! i bet it feels good to see it coming together :-)
Its still a long ways away but it does feel good to be getting somewhere with it.
Old Aug 19, 2008 | 06:14 PM
If you click on the link in my sig, you can see all of them. I'vs got a lot going on right now with heather and I loooking at houses but I'm going to try and get a lot done before we actually move.
Old Aug 24, 2008 | 05:27 PM
Well Heather had plans today so I had to paint the frame myself. I also got the bed bolted down and the fuel cell half way bolted down.
Old Aug 27, 2008 | 04:37 PM
Rusty's 4" front leaf springs
Hopefully sometime this weekend I will have the time to get them installed along with the front D60.
Old Aug 27, 2008 | 05:02 PM
challenger's Avatar
WOW Nice JOB there 78D200 looks like you have alot of time on her and boy its sure nice to see someone take time and build one of them up as nice as you are doing , sure would be neat to have a ride in it when your done but you would have to drive over here LOL hope you keep up the good work and remember to take your time and it will all be fun in the end with a great time in the dirt / snow ewwwww snow i sure dont want to see that yet but its coming hehehe anyway great job and keep up the great work and we will be waiting to see her when it is all done
Old Aug 31, 2008 | 02:41 PM
Well Heather and I got the new front leafs in place. Heather has to work tomorrow so I'll probably end up burning out the bushing out of the chevy leafs and get them cleaned up. Hopefully this week I'll be able to get some bushings for them and get the rear suspension set up and ready to be welded in by next weekend. All that I'm waiting on now is the stuff I ordered from Ruff Stuff and I have to get a set or rebuild kit for the king pin joints on the front D60.
I was also able to get my driver's side door latch problem fixed.... at least for the time being.
Old Aug 31, 2008 | 09:21 PM
challenger's Avatar
You know i have to say it but ( you might be a red neck if you have a gate lock on your truck door ) hehehehe just kidden thats a good idea but what are you missing to make the latch work and good luck on the king pin joints <<<>>> keep up the good work
Old Sep 1, 2008 | 03:43 AM
its the latch itself. one of the springs and levers is broken and nobody around me has a pre 78 door latch. from 79 and later are different (figures since I have 2 79s sitting at a friends house). Once the cab doors start to take a beating, I'll be removing them and making new ones and will probably use a gate latch on both sides.
...... And yeah I am a redneck. lol
Old Sep 1, 2008 | 11:32 AM
Well this morning I was able to burn out the old bushing out of the chevy springs and get things clamped into about the position that they will be for the rear suspension. I've got to get my hand on some bushing and metal sleves for the springs and then I can really start to set it up. It's starting to look like its coming back together once again.
Old Sep 2, 2008 | 07:15 AM
Thats a good idea. It would be less likely to get ripped off while I'm in the woods than the latch that I'm using. I'll keep that in mind though.
Old Sep 5, 2008 | 06:47 PM
Tonight I got the new poly bushings installed and one hole drilling in the front two spring hangers for the rear springs. I had to drill the hole for the pop rivit for the crossmember that goes up and over right behind the cab. Once my stuff to bolt in the axles comes in next week, I'll be able to clamp the axles to the springs, set the vehicle on its own weight and start to weld in the rear hangers.
ITS STARTING TO COME BACK TOGEHTER!!!
Old Sep 13, 2008 | 03:35 PM
This is all you guys are getting for tonight. I'll get some better pics up tomorrow night so you can laugh at my welding skills.
Old Sep 14, 2008 | 01:00 PM
Well I got a little more done today. I was able to get all the hangers and shackle bolts torqued down and Heather helped out with getting some of the tires mounted on the beadlocks.
...... and yes this is a 3/8" thick diff cover.
Old Sep 16, 2008 | 02:34 PM
Well Heather and I got the wheel studs pounded into the hubs for the 14B and got the backing plates and the brakes on. Just have to get the right drums for it and then the tires will go on.
Heather has been a huge help.
Old Sep 16, 2008 | 04:30 PM
  #25
i hope you thank heather for her help. having an 'in house' helper is precious!
oh i have. she actually posted this pic on her myspace profile. lol
Old Sep 17, 2008 | 05:46 PM
  #26
Well, all I can say is thanks to Heather for kicking my @$$ into going to work on the j10 tonight. She sent me a text asking if I was planning on working on it today and I said that I wasn't sure. She said "oh.....". I asked if she wanted to and she said "np, its ok.....". I couldn't believe it, HEATHER WANTED TO WORK ON THE J10! I was thrilled and told her that I'd swing by the house to pick her up and we'd work on it. Well Thanks to her, we were able to get the whole rear alxe finished up and got the last two tire mounted. I'm still waiting on my stuff from Ruffstuff though. I think I'm going to give them a call tomorrow.
Old Sep 20, 2008 | 02:17 PM
  #27
Well Heather and I got the rear pretty much done, minus installing a vent hose, 3/8 diff cover and trying to get the pinion set up a little better. Still waiting on the hardware for the front axle. I'm going to give Dan at Ruffstuff a call and see whats up with it.
The 38.5s look small, but they will do till I can afford to upgrade the axle shafts and up the tire size to 42s.
Old Oct 1, 2008 | 05:38 PM
  #28
Heather and I got the front D60 in tonight..... then it started raining.
I'll try to get some pics this weekend since I've been working 12-14 hours a day during the week.
Old Oct 5, 2008 | 12:57 PM
  #29
Well the axle is in, the tranny cooler is mounted, the rear crossmember is ready to be welded in, and the diff covers are ready to be bolted on.
D60 Cover
14B cover
tranny cooler
front axle (no the knuckles are not attached, just sitting there)
Old Oct 5, 2008 | 03:42 PM
  #30
this will look great when its all done!
