70 roadrunner clone
Old Aug 17, 2006 | 11:57 AM
1 Bad Mirada's Avatar
Administrator
i am not 100% certain, but i believe that the cross member of a slant six car is different...as is the rest of the front suspension to accomodate the added weight. ive never seen a slant 6 runner, though.
as for the pros and cons of the 413 vs the 440. aside from the basic "pro" of the bigger engine, the 440 is a much more commonly modified engine, so parts are more common. Many of the parts, such as the manifolds, headers, heads, etc are interchangable between all of the B/RB blocks. however, some things, like performance pistons for a 413, arent even listed by the major performance manufacturers, like keith black, but everyone who makes mopar stuff, makes pistons for a 440. and when you do find the performance stuff for the 413, they may cost a bit more since they are less common.
Old Aug 17, 2006 | 02:56 PM
Administrator
he should know, however, that unless hes going for huge power, he can get good power and performance out of the 413. A good set of heads with a valve job, cam, intake, and headers for any RB motor will fit, and give you good performance. I have seen some very fast 413 cars, and if youre going for a unique approachm the 413 would be the way to go.
Old Aug 17, 2006 | 03:37 PM
Administrator
ahh...you know, i gave no thought to the "RR clone" idea...my mistake.
you are 100% right..if he wants 1 good clone, he will have to go with a 383, 400, or 440...unless he wants to shell out the for a hemi!
i have to wonder why the 413 even came up? rondogg, do you have the chance at a cheap/free 413? if so, you could simply remove badges on the 413, and throw something like a 383 or 440 pie tin on it. that would be the sort of "budget build"...as i dont think that there are no identifying marks on the engine other than the block stamp, and perhaps the pedestal on the front of the block, but you can smooth that out.
Old Aug 17, 2006 | 03:54 PM
Administrator
the 400 is the popular stroker motor right now...but like you said..money talks...im happy with my puny little small block...
Old Aug 17, 2006 | 04:11 PM
Administrator
there are some FAST slant 6s running in the chrysler classic events series...i belive several of them are in the 9s!
Old Aug 22, 2006 | 08:56 AM
Administrator
do you mean for a slant six, or for a 440?
if you mean for a slant six, there are companies around the country who specialize in slant six mopar performance...one that i know of is called *** racing...and i have seen several slant six cars run in the low 10s and high 9s.
Old Aug 23, 2006 | 07:53 AM
Administrator
i personally am partial to small blocks like my mighty 340...
Old Sep 12, 2007 | 03:47 PM
76Duster07SS's Avatar
Junior Member
no, dont worry about the crossmember, w/e engine you choose, just buy the appropriate swap kit for it, you will need to beef up the suspension and the brakes, i'm restoring my 76 'Feather' Duster, all i need is to borrow a buddys engine lift and yank it out and i'll be on my way to re-building it and probably beefing it up a bit, only has 30k orig. miles, kept in the family...but for your swap kit just go to this place>>>http://www.engine-swaps.com/ or here ManciniRacing
Old Nov 9, 2007 | 07:30 PM
moparsforlife said:
"you couldn't tell them apart from a 383 or 440 just by glancing at them anyways."
You most certainly CAN, at least in the case of the RB engines, which have the small boss on the passenger side of the engine, near the distributer. These pretty much all had a stamping that ID's the CID, IE 440, 426, 26, 413, etc. The low deck engines did not have this boss.
So far as the cross member, I don't remember, it SEEMS to me that it won't clear the pan
I would CERTAINLY go for a 440 over a 413. Also, there is a lot of difference in brakes, sway bar, and torsion bars betwen even the 383 cars and such things as my old six pack. I wouldn't have one of these nowadays with drum brakes.
schreeky
Jan 13, 2011 08:37 AM
Dizzle
Aug 23, 2010 03:47 PM
souljour2000
Dec 2, 2009 09:28 AM
thick10
Nov 6, 2009 10:55 AM
WHiPLASHER
Jul 15, 2009 09:56 AM
