HELP! my fury won't idle all of the sudden
Old Jun 29, 2008 | 01:57 PM
ninjafury's Avatar
I have a 66 fury III with a 318 poly. It is my daily driver & up untill today it ran well. I recently replaced several parts, did a full tune up & I have been driving it daily without many problems. I did have a problem with the connections going throug hthe firewall but I have solved them. The car has great spark, it's getting fuel & I don't think the timing chain slipped. It will start & run great if I keep the RPMS up but the second I let my foot off the gas it dies! I'm am out of ideas. Anyone?
Old Sep 18, 2008 | 12:15 PM
Commando's Avatar
That is that same issue I am having with my 400, vacuum leak. You may want to do what I am inprocess of doing, trace your vacuum lines and run a propane torch unlit over the lines to see if the idle changes, when it does there is your leak, also run it over the gaskets on the intake and the carb. Hopefully you find your leak, if not you are in my boat and I am still trying to track down the leak.
Old Sep 18, 2008 | 01:05 PM
make sure your idle circuit isn't clogged
CRinWP
43
Nov 13, 2014 05:36 PM
bimmerman
Jan 14, 2014 09:51 AM
straightener
Oct 13, 2012 05:42 AM
sgp7679
Mar 4, 2009 06:06 PM
ninjafury
Jun 29, 2008 07:28 PM
