View Single Post
Old 07-03-2008, 09:40 PM   #17 (permalink)
64fury
64fury's Avatar
Well the install is done (99% anyways)
Everything is working fine except for a few minor things, first with the low beams on, the dash high beam indicator light is on, and when the high beams are on the indicator light is off.
Also when the lights are on, either head lights or park lights both dash turn indicators are on (not flashing) they flash when the turn signal are in use.
And I have front and rear park lights when the light switch is in park light mode (no headlights), but only rear park lights when the headlights are on.
I used kit#10102 and replaced the stock headlight switch with painless #80152, although any 3 position GM switch will do!
The kit is actually very easy to install, but plan on at least 3 full days, and save and reuse the OEM pigtails where you can.
__________________
64' Plymouth Sport Fury
58' Triumph TR-3A
72' MGB-GT
64fury is offline   Reply With Quote
