air grabber question
Old Apr 27, 2008 | 10:41 PM
I'm not sure if the actual part was different or not. I CAN tell you this--there is very little difference in height between the B and RB engines. So far as fitting in the car, I doubt it will be an issue. You'd probably change the installed height much more with differences in manifolds and carbs, IE Carter vs Holley, and aftermarket vs factory manifolds
Old Jan 7, 2011 | 10:12 PM
Hick727's Avatar
Originally Posted by Doc
I will BET that the AG hood assembly is the same ...B and RB. The diff in height ...is made up with the air-cleaner assembly.
I hate having to resurrect a old thread but what is a B or RB engine? Whats the difference?
Old Jan 7, 2011 | 11:54 PM
1966sportfury's Avatar
A.K.A Bob Dodge
b is the 383/400, rb is raised block. 413/440/426
Old Jan 22, 2011 | 09:14 AM
jpickar's Avatar
About 30 years ago when I was in on the ground floor of restoring these cars I ran into the same question. I went to the Dodge-Plymouth dealership and had them check in thier parts books.
The base plate for the 440 and 383 are the same in part number and height. I actually measured a factory 383 RR to a factory 440 GTX 4 bbl air cleaner. The Rubber seal on the hood has the ability to make the difference up. The seal was designed to have enough "give" in it so the torquing of the engine would not hit the fiberglass.
By the way I'm new here and am glad to find this site. I have been out of the car circuit for several years and was in Phoenix last weekend and went to a car show and enjoyed it very much. I live in Montana now.
John
Old Jan 22, 2011 | 11:37 AM
Silverick's Avatar
John
Welcome John,
Glad to have you!
Old Jan 22, 2011 | 02:12 PM
jpickar's Avatar
Thanks Silverick,
I hope to learn a lot here as things are different now than when I was buying cars for $1000 complete and getting parts from the junk yard. I did find some neat stuff in the junk yards.
John
Old Jan 30, 2011 | 04:52 PM
ricky d's Avatar
so u think i can use a 383 base on my 440 i also have a RPM intake will the hood close?
Old Jan 30, 2011 | 06:03 PM
jpickar's Avatar
I do not know what height a RPM intake is so I couldn't say if your hood will close.
John
hmiller79
Jun 1, 2019 09:30 PM
roadruner150
May 10, 2012 12:55 PM
esimmons178
Jan 15, 2012 06:23 PM
BuckNeccid
Jan 17, 2009 02:11 PM
BuckNeccid
Dec 20, 2008 05:51 AM
