View Single Post
Old 07-28-2008, 04:40 PM   #6 (permalink)
Commando
Senior Member
Commando's Avatar
Today I ran the engine to see what happens when it warms up, and also to check and see if there were any vacuum leaks. I didn't find a leak, but the engine started to overheat, so I added coolant to the overflow. I then opened the radiator cap and could see the top of the fins so I topped that off and ran it again. I shut it off and could hear the coolant in the water jackets bubble, so I figure that the thermostat is bad.
Any other thoughts?
I will be replacing the fuel filter and clean the carb as well.
Commando is offline   Reply With Quote
