Opinion Needed
Old Jul 30, 2008 | 04:16 AM
Commando's Avatar
What I would look into is a throttle body spacer, it doesn't need to be done with the engine out of the truck. I installed one about a month ago in my Ford Ranger 4 cyl, I saw a jump in horsepower, minimal mpg increase, and awesome throttle response. I think the brand I got was helix, have the box lying around somewhere. Some of the throttle body spacers out there are crap though, this one directs the air better to increase oxygen and makes it run smoother.
I am sure there are better things you can do with the engine out, but that is something I would look into for your truck.
Old Jul 30, 2008 | 08:44 AM
i don't know how over the edge this is, but you could look into a cold air intake. It'll give you a lot more power, and not kill you on the gas mileage.
Old Jul 30, 2008 | 09:46 AM
Commando's Avatar
I should have suggested that too, when I wanted to boost horsepower and gas mileage I was told that I should get the throttle body spacer and the cold air intake. Another recommendation I heard was a programmer to adjust the computer.
Old Jul 30, 2008 | 06:12 PM
Commando's Avatar
If you go to Edelbrock's website they will recommend a cam that goes with the heads, just a good starting point if I were you.
Old Aug 1, 2008 | 01:58 AM
Make sure that teh heads that you are getting are for a Magnum motor and not a LA motor. The two will be different. Edelbrock does recommend a cam to go with their heads most of the time, so check out their website. Also look into getting a good quality set of headers.
Since you will be going with a larger throttle body and cam, look into getting your computer reprogrammed so that way it knows how to compensate for the performance parts that you are installing.
Old Aug 17, 2008 | 08:16 AM
How did it turn out?
Hal9000
Nov 29, 2012 02:44 PM
Silverick
Apr 10, 2012 09:19 PM
boyswithtoys1971
Aug 21, 2010 09:00 PM
crxnug
Sep 6, 2009 07:44 AM
sgnrulz
Jul 19, 2009 06:15 PM
